Reading and processing high freq data in different processes
I am trying to create a program to receive raw data from UDP - EGD protocol, process the raw data then write data to file. The max transfer rate is 100 Hz and when running at this frequency the program cannot seem to process the data quicly enough to maintain a constant timestep ie the interval between data samples is not constant. Any suggestions how I can overcome this problem? I can post the VI if it will help...
(2,857 Views)
Please stop creating multiple threads and questions on the same issue! Smiley Mad
(2,851 Views)
Duplicate post...
http://forums.ni.com/t5/LabVIEW/Reading-and-processing-high-freq-data-in-different-processes/m-p/174...
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(2,837 Views)
