RT PID toolkit does not match standard PID toolkit for arrays
Hi Angela - the VI you posted seems to fix the issue I described, but there's another bug in the PID toolkit which affects both the array and single-point versions, reported here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=246177.  Any chance of posting another corrected version?
Message 11 of 12
(2,300 Views)
Hello nathand,
We do not have a corrected version of this VI at the moment.  As you mentioned in your post in the other thread, you can modify the PID advanced VI for the time being.  We will implement a fix in the next version.  For now, you could change the following case structure:
As follows, and this should help.
Thank you for bringing this to our attention and please post back if you have any other questions about this.
Best Regards,
Angela M
Applications Engineer
Message Edited by Little A on 05-22-2007 10:49 AM
Message 12 of 12
(2,232 Views)
