RT network stream -314004
I am working with LabView 2014 and cRIO 9073 and I'm trying to build a Network Stream. I always get the error -314004 even in the "UI Main.vi" which is generated in a new Real-Time Projekt.
I think I'm missing a software package on my cRIO but I don't know which one. I already installed "Network Streams 14.0".
Thanks for your help
Message 1 of 9
(5,760 Views)
Do you have any code you can share?  My guess is that you do not have your IP Addresses correct.
Message 2 of 9
(5,748 Views)
My cRIO's IP Adress is 192.168.178.101 and PC 192.168.178.28
both are connected via ethernet kable to a router.
Message 3 of 9
(5,723 Views)
it seems the create-writer times out before the connection is made
http://zone.ni.com/reference/en-XX/help/371361L-01/lverror/streams_error_codes/
it works for me (setting the writer timeout to "-1") and starting it first like so
and afterwards the reader
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 4 of 9
(5,708 Views)
on localhost it works fine but when I'm runnig the writer vi on my cRIO it does not work....
on the cRIO I also get the error -314000 which leads me to missing software but I insalled network stream  via MAX. Is there an other package that has to be installed?
Message 5 of 9
(5,691 Views)
i dont think so, but i dont know for sure.
for comparison my own software on the crio9068:
Message 6 of 9
(5,679 Views)
I tried installing all the software and now cRIO is in safe-mode because of a software error 😞
this always happens when I install to much software at least I think that is why
Message 7 of 9
(5,671 Views)
Accepted by topic author Chamsta
Ok after a few more tries it is working 🙂
I now have the following software configuraion and I hope I won't have to change it again.
Thank you for your help
Message 8 of 9
(5,634 Views)
I have the same problem on LabVIEW RT 2015, using cRIO-9066.  I installed Network Streams via NI Max, that did not solve the problem.  Then I installed Network Variable Engine and Variable Client Support, but I still get the same error.
Message 9 of 9
(4,885 Views)
