RT programming for cRIO/sbRIO *.ctl cluster
See the attached!
For a *.ctl (control) that's a cluster:
1. How is Index Display added? For the attached example, I know it is displayed by Right Click -->Visible Items. But when created from scratch, this option is unavailable.
2. Why would one use and Index Display on such a control?
3. There's a number in the upper RH side of the icon of the *.ctl. What does this indicate and how does it change?
Message 1 of 23
(4,359 Views)
  • Clusters don't have indices, only arrays.
  • The number in the icon is added whenever you create a new control. Open it in the control editor and change the icon to anything you want.
It is typically preferable if you could attach an actual VI (or control) instead of pdf documents.
Message 2 of 23
(4,350 Views)
You have an array of clusters.  The cluster (I'm assuming that's what you have since that is what you said) is saved in the .ctl file as a typedef.  There was an array container dropped into the block diagram, and the control was dropped into that and set to show as an icon.
Message 3 of 23
(4,343 Views)
I am not seeing this comes from an array. It's a cluster with Index Display. The code is from the 2012 cRIO Developer's Guide you can download here
ftp://ftp.ni.com/evaluation/crio/compactrio_developers_guide
Message 4 of 23
(4,296 Views)
As already stated, it's an array of clusters. Not sure why you don't believe this, but since you don't, look at the type of the wire. Wire that constant to the edge of a for loop. Turn on context help (control-h) and put the cursor over the wire. You'll see that the data type on the wire is an array of clusters.
Message 5 of 23
(4,274 Views)
Just be careful - remember that when programming on RT there is no front panel in an RT app (except when you're remotely connected).  In RT you cannot reference front panel objects via property nodes or the like, but you can reference them like variables so long as you're just using it as data storage like a global variable but in a more "local" scope.  When using front panel objects, be very careful and be sure to keep to RT programming best practices.
-Danny
Message 6 of 23
(4,250 Views)
Nope, it's not an array. Download the code and have a look for yourself.
Message 7 of 23
(4,213 Views)
What you have is an array, of which each element is a type defined cluster. The array contains the cluster. When you right click the array and open the type definition, it opens the element definition, which is a cluster. The item on the block diagram is an array that contains that cluster type as the array element.
To generate the same thing yourself, drop an array constant on the block diagram. Then drop the cluster type definition onto the block diagram as a constant. Drag the cluster into the array and you'll see the result matches what you already have.
Message 8 of 23
(4,207 Views)
I've already tried that experiment. It's a cluster. Open Recipe Phase.ctl from the project tree under the RT target under the TypeDefs folder.
Message 9 of 23
(4,203 Views)
Well, in that case the other possibility is that the array is party of the type definition. Sorry, posting from mobile, can't download the code right now, but I will later.
Message 10 of 23
(4,197 Views)
