Using Tab Control Labels as controllers of Case Structure cases
Dear all,
I have a basic question.
I want to use the tab control label string as a trigger for the case structure options. Sorry for not uploading my program since it is too complicated.
I wonder how I should extract the label strings (each page's name string) so as to be able to use them as initiators for different cases of a case structure.
I appreciate your time in advance.
Arman
(3,320 Views)
Accepted by topic author ArmanLD
That makes no sense. You simply wire the control to a case statement. It's an enum and the case statement accepts that. With a right click, you can create a case for each tab.
(3,316 Views)
Dear Dennis,
Piece of a cake!
Thank you for the direction.
(3,298 Views)
