RT source code won't run, but RT application works fine. Packed Libraries are involved.
Good afternoon,
I'm trying to build a small test application using a framework we've developed internally (classes contained in libraries, modules launched dynamically in a similar way to the actor framework) which up until now has been used on windows based targets exclusively. We distribute the framework internally and to clients via a packed library.
  • Running from source with the framework as source code within the project works as both a RT Application and from Source
  • Running from source with the framework as a packed library doesn't work (Semi typical deployment error RT3.lvlib:RT3.lvclass:Main.vi loaded with errors on the target and was closed), yet the RT Application works fine.
Does anyone have any thoughts as to where I should be looking?
Peter
(2,048 Views)
I just want to update this in case any one else has a similar issue - I am currently working on a Service Request with Peter on this issue. I will update this when we have found a solution.
So far, we have looked at their framework, and then compared it to the Actor Framework Fundamentals example project - neither of which will deploy to a cRIO correctly as a Packed Library. There is, however, an Actor Framework As Packed Library project, which deploys successfully, which we are currently looking at.
(1,947 Views)
Peter and his colleague have shifted the focus of their application which has avoided this issue. As such, this has begun a matter of reduced priority for us to investigate.
However, we may come back to this, and if anyone has any suggestions, please feel free to mention them!
(1,919 Views)
