RTD simulation for cRIO-9217
We are building a test device for testing our cRIO system. The test device sends a variety of physical voltages and currents to the inputs of cRIO modules, and checks the resulting data produced by the embedded software. This is of course straightforward if the modules are voltage-input and current-input. However, one of the modules is a cRIO-9217 for sensing RTDs. Since we don't have a device that can programmically deliver different physical resistances, we are looking for a way to wire voltage or current into the terminals of the cRIO-9217 that would emulate a resistance. Do you have suggestions on how to do this?
Thanks for your help.
(3,138 Views)
If you want it traceable and reliable, I would suggest precision resistors (Vishay) and relays or in case of 4 wire modes maybe with analog switches ...
Greetings from Germany
Henrik
LV since v3.1
(3,130 Views)
Hello Chris,
If you havn't solved this yet, we at WireFlow has a cRIO module that I think would work.
Take a look at http://www.wireflow.se/products/WF3144
Hope this helps.
/Johan
(3,098 Views)
