RTM for VI in PPL
Hi All,
I am facing issue in setting the runtime menu for a VI inside a PPL. I tried setting the menu statically as well as programmatically (using property node) but the default menu is shown always. When I read the value of the RT Menu property back, I get the value that I have set, but the menu shown is default.
Please let me know if any of you have tried this and you are able to get it working.
Sree
(2,663 Views)
tl:r; If you can include the RTMs in your library, this is no problem. If they need to be separately edited (and not part of the lvlibp file), maybe it's tricky/impossible...
If I understand the problem you're trying to solve correctly, then I've attached some simple files showing it working (for LabVIEW 2017 32-bit Windows).
I included my compiled PPL, but of course for a different platform you can recompile.
Basically, I created a library with a single VI containing code much like you show in the image (taking a path input) and then a RunTime Menu with just the About LabVIEW dialog. I made sure to compile it with the default menu set. I then pass a path to the RTM, but in my case, (since the RTM is inside the PPL) the path looks like: <Current VI's Path (next to PPL)>/../MyLib.lvlibp/CustomRTM.rtm
Testing without a path connected shows the default RTM. Once I connect the path, I get the RTM compiled into the PPL.
If you don't want to use RTMs compiled into the PPL, you might have a problem (maybe this is what you wanted to do?) - I wasn't immediately able to use the same path (i.e with the MyLib.lvlibp section removed) to set the path - the indicators show it was found, but the menus didn't change.
GCentral
(2,588 Views)
Not sure how you fared with my last post, but here's a link discussing RTM in exes - it seems like they also have some requirement that they be included (perhaps).
https://forums.ni.com/t5/LabVIEW/Right-Click-menu-appears-as-default-in-build-even-when-it-was/m-p/3...
GCentral
(2,578 Views)
