RUN TIME
Hi everyone,
I need help with Run-Time Labview. I build an application (exe) with Labview 8.5 Professional and I'm trying to run this executable with Labview Run-Time 8.6 but I got an error.
Are the two version compatible. I can run an application build with an older version with a newer one?
Pierpaolo
(3,108 Views)
NO,
Build in 8.5 run with 8.5 RTE the
(3,106 Views)
Is this true for all labview version?So the RTE can run only applications build with the corresponding LABVIEW verison?
Pierpaolo
(3,098 Views)
Pierpaolo
YES, its true. Take a note - RTE is free, so you can download and install LabVIEW Run-Time 8.6 for running application developed with LabVIEW 8.6.
(3,090 Views)
Thanks guys for your help
(3,083 Views)
