Random number Generation
What will be the best way to generate random numbers from -1 to +1.
(4,459 Views)
Accepted by ade77
(4,458 Views)
Thanks Pnt
(4,446 Views)
The above code will give you one such number.
Since you want numbers(plural), use "uniform white noise" with an amplitdude of 1 and you'll get an entire array full of any desired lenght. 😄
(not available in LabVIEW base)
Message Edited by altenbach on 11-04-2008 11:45 AM
(4,435 Views)
Thanks Altenbach, This is actually a more general solution, applicable more to my situation
(4,424 Views)
