Random number Generation
What will be the best way to generate random numbers from -1 to +1.
(4,458 Views)
Accepted by topic author ade77
(4,457 Views)
Thanks Pnt
(4,445 Views)
The above code will give you one such number.
Since you want numbers(plural), use "uniform white noise" with an amplitdude of 1 and you'll get an entire array full of any desired lenght. 😄
(not available in LabVIEW base)
Message Edited by altenbach on 11-04-2008 11:45 AM
(4,434 Views)
Thanks Altenbach, This is actually a more general solution, applicable more to my situation
(4,423 Views)
