Random number generator. Even and odd numbers
I have a problem.
I have a random number generator, it goes from 0 to 20, I need to have two indicators, one will show how many numbers are pairs, and how many are not.
I tried to use the decimated 1D array, but since those numbers are random, it doesn´t work for me. I´m new with LabView, and I don´t know if there is some other way to make it work, I need some help, especially with some examples.
Thank you so much.
Message 1 of 24
(4,895 Views)
Your thread title says "Even and Odd numbers", but your description of the problem states 'pairs'.
Can you clarify exactly what you are trying to do.
Message 2 of 24
(4,875 Views)
What do you mean by "pairs"?  Just that a number is duplicated or that you have two of the same number back to back?
GCentral
Message 3 of 24
(4,869 Views)
Hi.
I need to indicate how many numbers are even and how many are odd
Thanks.
Message 4 of 24
(4,824 Views)
Thanks.
Message 5 of 24
(4,823 Views)
I don't think your issue is necessarily with LabVIEW, although your unfamiliarity with it might distract you from what you really need to do.  Have you thought up of how you would do it on paper yet?  Maybe base your sorting on whether or not dividing by two leaves a remainder?
Bill
CLD
(Mid-Level minion.)
Message 6 of 24
(4,811 Views)
Spoiler
Create the array.  Use quotient remainder to divide by 2.  Now you have an array where all the odd numbers are now 1, and all the even numbers are now 0.  Sum the array and you have the total number of odd numbers.  The number of evens will be the length of the array divided by the # of odds.
Message 7 of 24
(4,810 Views)
@RavensFan wrote:
Spoiler
Haha I lost sight of the fact that he was looking for the amount off odds and evens.  Good one.
Bill
CLD
(Mid-Level minion.)
Message 8 of 24
(4,799 Views)
Typically it is more efficient to do a bitwise AND with 1. You get zero for even and one for odd.
How are you generating the random numbers?
Message 9 of 24
(4,784 Views)
@RavensFan wrote:
Spoiler
"The number of evens will be the length of the array divided by the # of odds."......you mean subtracted not divided?
Message 10 of 24
(4,778 Views)
