Showing results forĀ
Search instead forĀ
Did you mean:Ā
Ransac Implementation
Hi everybody.
Someone knows how to implement the RANSAC algorithm to obtain a map in 2D or 3D en Labview.
I have the data from a stereo camera, and I'd like to build the space in 2D, or 3D if is possible.
"Everything that has a beginning has an end"
(5,336 Views)
Would you mind posting the format that your data is in?
Applications Engineer
(5,300 Views)
Thanks Patricia for worried about my problem.
Look, I'm obtaning a matrix, the dimension of the matrix is 480x640, in the matrix I have the range of each pixel in the image.
Could you help me with the implementation?
(5,283 Views)
Hi Anfedres86,
There aren't any LabVIEW VIs or examples that use Ransac.   You will need to build the algorithm yourself in LabVIEW.   I did find a good link that explains the Ransac algorithm.  This might help you in building your implementation.
Best Regards!
Starla T.
(5,271 Views)
Hi I don't know about implementation of RANSAC in Labview but you can use this below link to understand about RANSAC
https://www.sri.com/sites/default/files/publications/ransac-publication.pdf
(4,058 Views)
