Raspberry PI installed uncorrectly on LabVIEW 2014 with LINX 3.0 (yellow warning)
Good Afternoon everybody
Well I create this thread because I cant connect with my RPI with LabView2014, i going to put different screen shots, as you can see i already install the LINX 3.0 on my computer.
My computer sistem
-Windows 10 64 bit
Already Installed products
-LabVIEW 2014 32 bit
(this labVIEW I downloaded from the link of the tutorial PDF)
-LINX 3.0
-Control Design and Simulation Module
-MathScript RT Module
-NI VISA
-VI Pakage Manager
-Also i have my license for the activation
I going to upload others print screens in this same post
Ruben Rhico
Message 1 of 10
(7,677 Views)
Accepted by Rhico
Hey Rhico,
Make sure you've restarted LabVIEW since installing LINX.  If the issue persists follow the instructions from sharpk in this thread.
Let us know if that resolves the issue.
Thanks!
-Sam K
Message 2 of 10
(7,656 Views)
To restart Labview i only close all the windows of labview and open again?, thats the way? or i have to do other things?
Message 3 of 10
(7,646 Views)
Thanks Sam_K it function, i have to unzip a folder and paste in another part of the folder of national instruments
Really Thank you very much!!!
Message 4 of 10
(7,645 Views)
What, exactly, did you "have to unzip and paste"?  This sounds like a recipe for disaster.  Something like that can cause strange, impossible-to-troubleshoot issues for the rest of forever.
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(7,599 Views)
Hi Bill
Look this link https://www.labviewmakerhub.com/doku.php?id=libraries:linx:faq#22
Here is the instruction of the unzip folder and where you have to paste, i think its because the libriry is not unzip in the right folder.
Let me know if you understand or if you have any questions
Regards
Rhico
Message 6 of 10
(7,557 Views)
@Rhico wrote:
Hi Bill
Regards
Rhico
I actually used LINX to deploy an NTP service monitor to my RPi3 and I don't recall having to unzip anything.  Did you download LINX directly?  I used VIPM to download LINX.  That's probably the best way to do it.
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(7,545 Views)
Okay, I see it at the very bottom of the FAQ.  I guess you did install it manually.  Unless you had some kind of issue with VIPM, I would highly recommend installing through VIPM instead.
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(7,544 Views)
Yes, you can solve the problem install manually, thats what I do
Message 9 of 10
(7,519 Views)
Excellent!
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(7,514 Views)
