Re: Calling two Sub VIs using Test sequence
Hii All,
I created main vi and one sub vi...i wanna to call sub vi from main vi using test sequence and controller is Bollean.
Means when the test sequence detects true condition it will run main vi and when test sequence detects False condition, it will run sub vi.. But sub vi is nit running...can some one tell me the solution...
With Regards
Puneet Kapoor
(3,120 Views)
I think you must take a look at the Basic examples shiped with Labview.. there are many info at ni.com and at this forum too.
(3,098 Views)
Accepted by topic author Puneet_K
thans for the suggestion...
i got the solution for it n the VIs is in the attachment.
Message Edited by puneet.kapoor on 12-12-2007 10:10 PM
(3,087 Views)
