error: Math script code giving only zeros..
I have this code . I know it works in MATLAB. I tried to make it work in MathScript but in the last step, i only get M to be a zero matrix. however it should have values then. What is wrong??
t = (0:0.0000001:.01);
f1 = .0011312*cos(2*pi*49400*t);
f2 = .0033936*cos(2*pi*100*t);
H = (f1 + f2);
x = ((2.93464*10^-10)*H);
ms=1000;
M = ms * (coth(x) - (1./x));
(4,331 Views)
I think someone suggested entering the code into the Mathscript Window line-by-line, so that you can see the progression of your variables. For a small script like this, it's a great way to  debug it.
Jarrod S.
(4,329 Views)
I have input the code one at a time. It shows values of all them except M. I get H, x, ms, everything except M.
(4,325 Views)
I tried your script in Matlab 6.5.1 and I essentially got zeros for M. It sort of makes sense. The array x is an array of exceedingly small numbers (on the order of 10E-12), which is effectively zero. The coth of 0 is undefined.
(4,311 Views)
> H = (f1 + f2);
> ms=1000;
I wouldn't trust the answer in either Matlab or Labview. Wirh X being
approximately 1 x 10^-12 the coth of x and 1/x are both approximately
1 x 10^12 you are trying to calculate the difference between two very
large numbers. This is often an invitation to a disaster. I suggest
you rework your equations to eliminate the problem of determining the
difference between two large numbers.
Howard
(4,301 Views)
> > H = (f1 + f2);
> > ms=1000;
> Howard
I took another look at your question this morning and noticed most of
the values Matlab gave for M were equal to zero. Then I visually
compared some values of x that produced an answer of zero for M and
those that gave a non-zero value. Here is the comparison for Matlab.
show = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10];
>> x(show)
ans =
1.0e-011 *
Columns 1 through 7
0.1328 0.1328 0.1327 0.1326 0.1325 0.1324 0.1322
Columns 8 through 10
0.1320 0.1318 0.1315
>> M(show)
ans =
Columns 1 through 7
0 0 0 0 0 0.1221 0
0 0 0.1221
Notice how close the x values that gave a zero result are to the x
values that gave a non-zero result. That doesn't make sense. Hence I
conclude your problem as presently defined isn't suitable for Matlab
or Labview.
Howard
(4,281 Views)
> H = (f1 + f2);
> ms=1000;
Another update. I ran your code in Matlab using variable precision
arithmetic as follows.
>> digits(25)
>> y = vpa(x);
>> z = y([1, 2, 3, 4, 5, 6, 7, 8, 9, 10]);
>> 1000 * (coth(z) - (1./z))
ans =
[ .5000e-9, .4000e-9, .4000e-9, .4000e-9, .4000e-9, .4000e-9, .
4000e-9, .4000e-9, .5000e-9, .5000e-9]
The answer given by variable precision arithmetic for the first ten x
values is completely different than the values given by double
precision arithmetic.
Howard
(4,260 Views)
