Re: Connecting to multiple KVASER - Leaf Light HS at once....
I am trying to connect 2 Kvaser (USB) dongles to my computer using LabVIEW simultaneously...
They are connected to the computer with a USB Hub but that shouldn't make any difference.
I have: CANKing CAN bus monitor program and the Kvaser SDK and their LabVIEW library also - all installed.
When I run CANKing, the program can detect both USB devices and also the 2 virtual channels - 4 in all.
When I call the CanGetNumberOfChannels.vi the value returned is 3 - but should be 4.
I am assuming that the CANKing program uses the same API calls.
Any ideas, why the second device is not recognised??
(4,441 Views)
Hi Sammy,
If you use the devices one at a time, does the CanGetNumberOfChannels.vi return the proper value?
Best,
Jeff S.
(4,410 Views)
Accepted by sammy346
I have seen this behaviour before, it is nearly impossible to cleanly unload the Kvaser dll when it is misbehaving.  Re-starting LabVIEW may help.  If the Kvaser hardware configuration tool shows 4 channels, then the CanGetNumberOfChannels dll call should reflect this.  It is not a good idea to add or remove a device with the driver loaded.
All the best,
Michael.
(4,403 Views)
Yes,
I was playing around with it further again yesterday and just calling a dll directly without using the VI (which is basically the same thing).
Results have been inconsistent although I was able to get the dll to recognise four channels at one point.
(4,395 Views)
Just came across your question here.  An answer to your question is on our website at:
http://www.kvaser.com/en/support/faq/270-labview.html
As the FAQ at the link states, the problem arises due to when the DLL is unloaded.
(4,346 Views)
