Re: Darren's Weekly Nugget 06/26/2006
Hi Darren
How would you use this in a state machine?
Message 1 of 10
(4,172 Views)
Hi KJ,
Basically the very same way, with providing an "N" and "i" input…
Message 2 of 10
(4,149 Views)
Ye i tried it - please see below
This is in one of my state machines
Message 3 of 10
(4,136 Views)
(I recommend to start a new thread instead of appending to a 15 year old thread. You can always give a link to this thread if needed. You can ask the moderator to split off your sub-thread.)
It is completely useless to show a truncated picture with meaningless code (e.g. why does the string array go through the FOR loop if it is not used but and just emerges unchanged later? Why is the "waiting" constant on the right? etc.)
Message 4 of 10
(4,124 Views)
Hi KJ,
here's the link to Darrens 15-year old nugget
What's wrong with it? It should work as programmed!
(Maybe your expectation is wrong: the loop will iterate as fast as possible over that string array and so the progressbar will fill up very quickly…)
Message 5 of 10
(4,100 Views)
The  picture was just an example, not my actual code - i have literally read your description and tried to replicate it. Maybe your example is redundant.
Message 6 of 10
(4,040 Views)
Accepted by KJ26
I tried it and it works fine for me. You are just using it wrong.
or this, it's even shorter
Message 7 of 10
(4,036 Views)
Ok Thank you
Message 8 of 10
(4,025 Views)
Hi
I have a button that calls 7 cases to update a database but i want a progress bar to pop up to show the process of going through these states.
help will be much appreciated.
Message 9 of 10
(4,014 Views)
I would use the FOR loop sequencer.  It is basically a state machine, but using the i terminal to decide which case to call.
Message 10 of 10
(3,977 Views)
