Re: How do I write signals'names on the TDMS file using CAN bus without having to hardcode every single of them?
rt089_1-1600927811839.pngFig.1
rt089_2-1600928063122.pngFig.2
I am trying to run "CAN INput Stream to TDMS logfile" example from "NI Example Finder", but I encounter an issue as shown in Fig.1 above. I used different file path and cluster name as shown in Fig. 2. Could anyone help me to solve this issue? Thank you beforehand.
Message 1 of 11
(2,576 Views)
Hi rt,
which system do you use to run that VI?
Is the filepath available to this system?
Message 2 of 11
(2,572 Views)
Accepted by topic author rt089
Hi GerdW,
I am using cRIO 9045.
May I know what do you mean by "filepath available to this system"?
I just copied the example VI file into my folder where my Labview Folder located.
In "TDMS open", I chose "create or replace" and file path is the same folder where I saved my VI. Still, I am not able to create the tdms file.
My file path is
D:\Document_Ddrive\CAN VI\Gaurav_Model\logfile_test.tdms
Thank you very much.
Rudy
Message 3 of 11
(2,522 Views)
Hi Rudy,
My file path is
The cRIO is a computer on its own - which has NO ACCESS to the files located on the harddrive of your development computer!
(In general you don't want other computers give access to ALL files on your own computer nowadays - think about all those security implications!)
You need to deploy all files needed by your realtime target onto this target.
Did you read the cRIO basics tutorials?
Message 4 of 11
(2,511 Views)
Thank you very much for your explanation, GerdW.
For logging large amount of data over period time, may I know what is your suggestion?
Any recommended sources (e.g. website link) for cRIO basic tutorial?
Rudy
Message 5 of 11
(2,492 Views)
Hi Rudy,
LabVIEW comes with a lot of example VIs and projects. There are also several projects explaining the usage of cRIO targets for different purposes, like data logging…
For logging large amounts of data I would stream the data to your PC (when the cRIO is always connected to your network).
  1. See those Training resources in the header of the LabVIEW board!
  2. Look for tutorials in the Support library
Message 6 of 11
(2,474 Views)
@GerdW wrote:
Hi Rudy,
Hi GerdW,
Ok. In that case, can I use the tdms for logging the data and streaming it to my PC?
May I know how to create tdms file in cRIO? Is there any example?
Rudy
Message 7 of 11
(2,456 Views)
Hi Rudy,
You can use TDMS also in the cRIO.
You create the TDMS file the same as on a standard (Windows) computer using the TDMS functions. All you need to care about is using the correct local path of your cRIO! (Open the web interface of the cRIO, which you hopefully installed with the system setup, and browse for a nice path…)
For streaming data to your PC you should learn about using NetworkStreams!
Message 8 of 11
(2,441 Views)
Hi GerdW,
Thank you very much for your kind helps.
Is it the path which you referred to?
Message 9 of 11
(2,360 Views)
Hi Rudy,
the usual path is ni-rt/startup/data...
(The RTEXE is deployed to this startup folder.)
Message 10 of 11
(2,337 Views)
