Re: Repeated data.
Ok. Now I'll explain. The first VI that i built is what you see in the attachment called VI-1. Everything worked fine here except the fact that after about 50 minutes the program gave me error 200279. All the settings that i had entered (channel number, graphics, numerical indicators) were fine. Trying to solve the error 200279, i reconverted the VI as advised on this thread, but being new in labview i'm having problems now in reordering all the sensors with which i have to work (i mean graphs and numerical indicators). You can see this new attached VI (called VI-2). I think i did everything as you suggested, what am i doing wrong? For now i have inserted only one pressure sensor, i believe that understood the operation of only one then add other sensors will be simple. Can someone definitively correct the VI-2 please?
Message 31 of 41
(2,458 Views)
There are several things seriously wrong with your code.  I needed to make several "fixes" to get it to do anything "sensible".
Let me begin by saying that I don't have a cDAQ to use as a test device, so I substituted a USB-6002 and used AI0 as my (single) input channel.  I also diagram-disabled the DAQmx Configure Logging.
I notice that you are taking 1 Sample (at a time) at 1 Hz, yet you are collecting the (single point) data in a Waveform, which expects an array of data.  I changed the DAQmx Read to "Single Channel, Single Sample, Dbl", diagram-disabled the selection of the second element of the (now-not-present) 1-D Array of Waveforms, and wired the Dbl output wire directly to the multiplication-by-160 function.  [Incidentally, why are you doing this?  DAQmx is designed to report "real values" -- you shouldn't need to scale yourself.  And why add an offset of 0?].
I was a little surprised when I ran this program -- the Display updated its time, but showed me no values.  So I "unlocked" the static Y Scale you built into the code, and there were nice data, scrolling across the plot at 1 Hz.
See if this description of "How I Fixed Your Code" makes sense to you, and see if you can make the same changes.
Bob Schor
Message 32 of 41
(2,441 Views)
Hello. Thank you for your reply. Reading what you wrote, i understood that you watched VI-2. This is what i did   after the type of solution was suggested to me, but it is not very clear to me. I would prefer to continue to use the VI-1 ... but trying to solve the error 200279 (trying to give a name to each column of the excel file in output). I also downloaded the ADD-IN suggested by the NI website to convert a TDMS file to Excel, but the conversion is very long! To answer your question, if you look at the VI-1, i have to convert a voltage data to a given pressure; this conversion must be linear,so i introduced a scale factor (depends on the sensor i use) and also a value 0 (see it as the value that i can change, at any time, given by 'intercept of a straight line).
Message 33 of 41
(2,427 Views)
You really need to start reading the help file
Names , scales, all that happy stuff are handled inside DAQmx
Message 34 of 41
(2,412 Views)
Hi guys! I had to add the commands (blocks) "Get Date / Time in seconds" and "Get Date / Time string" to get the correct time and date in the excel data output sheet. I do not understand why it does not work. Did i make a mistake in configuring the "Set dynamic data attributes" block or did I block the blocks badly?
Message 35 of 41
(2,391 Views)
Sorry. I forgot to attach the vi and the image of the error!
Message 36 of 41
(2,386 Views)
You are setting Start timestamp only you need to add timestamp and wire to that
Message 37 of 41
(2,373 Views)
Hello! Thanks for the reply. Could you give me a screenshot of what you mean? Before asking, i read the help of each block, but i don't understand what i need to connect (specifically, i don't understand how to configure "Set Dynamic Data" block and how to connect it to "Get Date / time in second" block. I also believe that the "Get date / time string" is useless. Quite right?) I put the attached VI!
Message 38 of 41
(2,363 Views)
Accepted by topic author Iskandark
Message 39 of 41
(2,355 Views)
Thank you very much! 🙂 Tomorrow morning  i will try this solution!!!
@JÞB  ha scritto:
Message 40 of 41
(2,346 Views)
