07-12-2018 03:44 AM
Solved! Go to Solution.
07-12-2018 04:31 AM
Hi pleuratb,
In your implementation of vi you were required to build a Toeplitz matrix given the initial row and column of the matrix. Notice the first element of row and column should be equal. What will your Vi do if the initial element of each array is different?
Does anyone know the answer?
No, because the question is all about YOUR VI.
You didn't attach any VI…
07-15-2018 11:27 PM
Ask your classmates or your Instructor if you don't understand the assignment.
07-16-2018 02:30 AM
Thank you very much for your answer. This question is on manual "Digital Wireless Communication Physical Layer Exploration Lab using the NI USRP". I think that this is more a general question than a specific question related to my .vi.
07-16-2018
06:16 AM
- last edited on
07-07-2026
11:27 AM
by
Content Cleaner
There's also the built-in "Create Special Real Matrix" .vi , which is said to be capable to generate a Toeplitz Matrix.
