Re: Watlow F4 Controller with LabView
I have no code Smiley Happy
I just tried “open Visa” using the IP address and got an error (error code: -1073807343)
Message 11 of 15
(2,267 Views)
I have no code.....
Message 12 of 15
(2,267 Views)
Update….
I have downloaded a driver from
http://www.watlow.com/products/Controllers/Software/EZ-ZONE-LabVIEW-Driver-Software
Now I can communicate with the FT4 but the only operation that works in the initialization.
Did anyone use that driver? Is there a specific configuration for the FT4 to work?
I tried to use ParameterID: 27586 (which should be actual temp)
For the Zone I tried 0,1
For the InstanceId I tried 0,1,2
But nothing works.
Thanks, Erez
Message 13 of 15
(2,229 Views)
There should be a programmer manual which will provide all the information about commands.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 14 of 15
(2,216 Views)
In the manual P# 27586 is the temperature. Nothing about the zone, the InstanceId or the DeviceType
thanks, Erez
Message 15 of 15
(2,210 Views)
