Re: When I use the RS-232 or RS-422
Helo sir ,
Me sanaullah gulab
Regarding the flow meter
Sir , i m using Magmaster electromagnetic flow meter in the water irrigation plant.after servicing this flow meter give reading in Ltr/s . but i need this this reading should come in M^3/h
for this operation i communicate this flow meter with laptop through RS 232 cabel and software putty beta .I attaching some photos for this result which is comming in my laptop  screen.
problem is i am not able to write any command .
So pleas guide me quick
Email -   msgulab240@gmail.com
contect no   +917277274592
(2,896 Views)
Hi gulab,
why did you hijack an old and unrelated thread?
Multiply the reading by 3.6 to get values with unit m³/h!
Simple math: 1l/1s = 0.001m³/ (1/3600)h = 3600/1000 m³/h = 3.6 m³/h…
Read the manual of your device.
Ask the manufacturer support of that device.
i communicate this flow meter  …through RS 232 cabel and software putty beta .
How is your problem related to LabVIEW at all?
(2,887 Views)
Helo sir now my Magmaster flow meter problem is solved
(2,833 Views)
Hi msgulab,
Usually you provide the solution so other people with the same problem can learn from it…
(2,814 Views)
