Re: bluetooth error 54
I am trying the Labview with Bluetooth Protocol with the program mentioned here or with my program. I get the same error from the Bluetooth Open Connection VI for all connected Bluetooth devices.
Can you explain me the solution.
Regards
(3,571 Views)
Accepted by pavan250
Hi pavan,
unless you provide more information the solution will be: provide a proper IP address…
(3,522 Views)
Hi Gerd,
Thanks for the solution. I get a new error now "Error 59 occurred at Bluetooth Open Connection in Simple Bluetooth-Client.vi".
Possible reason: The network is down, unreachable, or has been reset.
The Project tested is in the examples i.e. Simple Bluetooth.lvproj.
I am using a Bluetooth USB device and the address of the device is found by the server program.
I have installed the required Microsoft drivers for the Bluetooth USB.
Can you explain the solution.
Regards
Pavan
(3,489 Views)
