Re: how i convert boolean to string ?
only the sensor is connected to the digital pin DIO0 in NI-9381 Module
Message 11 of 15
(909 Views)
Hi smalhao,
I don't think you can use a ScanEngine access to your DIO pins, it most probably is too slow…
(I guess you need to use the FPGA of your cRIO system.)
Message 12 of 15
(907 Views)
How i make a time digital acquisition where i record a digital waveform?
Message 13 of 15
(897 Views)
I didn't see anywhere that was mentioned this was on an FPGA.  But of course there are methods to read stuff fast on an FPGA.
This really should be its own thread and not a part of the original.  I'll split it out.
Message 14 of 15
(895 Views)
There is an example somewhere (might have to download it through VIPM) for I2C using a LabVIEW FPGA module.  1-Wire and I2C are similar enough, it might get you want you need.
However, I would just go with a DS2480B (serial to 1-wire driver chip) and use a serial port to get the readings.  It will save you A LOT of headaches.
Message 15 of 15
(891 Views)
