‎02-25-2019 09:31 AM
only the sensor is connected to the digital pin DIO0 in NI-9381 Module
‎02-25-2019 09:36 AM
‎02-25-2019 10:00 AM
How i make a time digital acquisition where i record a digital waveform?
‎02-25-2019 10:03 AM
I didn't see anywhere that was mentioned this was on an FPGA. But of course there are methods to read stuff fast on an FPGA.
This really should be its own thread and not a part of the original. I'll split it out.
‎02-25-2019 10:09 AM
There is an example somewhere (might have to download it through VIPM) for I2C using a LabVIEW FPGA module. 1-Wire and I2C are similar enough, it might get you want you need.
However, I would just go with a DS2480B (serial to 1-wire driver chip) and use a serial port to get the readings. It will save you A LOT of headaches.
