Re: repeatability of words in an array
Yes, data will be coming from an instrument. Lets take an example data is coming from USRP and all the frequencies above threshold will be displayed in the Array A indicator and you are right data reservation will be correct terminology. I want that all the elements of Array A remain reserved in Array B. If I use only outer while loop as shown in pic below:
Data starts continuously writing in Array B as shown in pic below:
Message 21 of 24
(338 Views)
The word "continuously" is very vague. You simply need to ensure that the loop only spins whenever new data arrives.
Currently, it spins millions of times per second creating duplicates and make you run out of memory quickly.
Message 22 of 24
(333 Views)
Yes, You are right. It is spinning millions of times per second creating duplicates.
Message 23 of 24
(328 Views)
Hi qureshi,
Until now you only defined which data should be appended to array B.
Now you need to define when (at which time) those data should be appended…
Message 24 of 24
(310 Views)
