Read All Files in a Folder
I have a large set of data. Many don't have similar names at all. They
all have the same data form (a 100x2 array for example).
Is there a way to have a VI read all the files, one after another,
automatically? It's a lot easier when the files are the same name, but
ending/starting with different ID numbers. If they're all different,
what can I do?
Also, is it possible to create a VI, so that a file 'dropped' onto the
VI's icon, will cause it to process the data? I'm not sure if this is
a Labview or MS Windows problem.
Thank you for your time.
-Dorian
dorianjps@hotmail.com
Please post if possible, to share.
(3,020 Views)
Dorian;
You can simplify this if all your files are in the same directory. Check the example attached that read all .jpg images in a directory and display them in a picture control. Enter the directory path before running.
As for your second question, it can be done, but I think (I might be wrong) that you must convert your vi into an executable. Check the following example:
Get Calling File Path from Command Line
Best regards;
Enrique
www.vartortech.com
(3,020 Views)
You may also want to check Mr. Jean-Pierre Drolet's "Guidelines to open your own file type from Windows Explorer" at his website.
Enrique
www.vartortech.com
(3,020 Views)
