Read hardware clock
For time stamping my data I would like to read the hardware clock on my
CPU board instead of relaying on the Windows system time whose accuracy
may be influenced by the workload of the CPU. From the old DOS times I
remember that this was made possible by issuing interrupt calls from
within a Basic program. How can I do that with LabVIEW? I guess that the
standard time functions which are provided with LV read only the Windows
system time. I am using WinNT 4.0 with LabVIEW 6.0.2. Thanks for any advice,
Frank
(2,883 Views)
Frank;
You may want to look at the article "What Clock Error Means to Your Measurement System by Darcy Dement. There are also several links to other resources.
Regards;
Enrique
www.vartortech.com
(2,883 Views)
