Read Data through RS232 4 Serial port and VISA parallely
Hi Vinay,
how can I control that 1st serial read and write has to read COM PORT 1 and 2nd serial read and write has to read COM PORT 2
By setting the correct VISA reference values…
Did you do any of those free learning resources offered for free in the header of the LabVIEW board?
Message 11 of 23
(2,090 Views)
Dear GerdW,
actually No. but I learnt LabVIEW  basic by LabVIEW resource which I got online Basic 1 and Basic 2
plz guide me if its there any free online tutorial for labVIEW from NI
Vinay
Message 12 of 23
(2,085 Views)
Hi Vinay,
I repeat: those free learning resources offered for free in the header of the LabVIEW board!
Message 13 of 23
(2,081 Views)
hooking up four devices to four com ports and querry/receive data in parallel is easy, but I guess it depends on how "parallel" you are hoping for.
I have done this with three wattmeters that communicate with rs-232 in one of my tests.
Now in theory with the VI's set to "preallocated clone reentrant execution" these three device should be read in parallel, but they are not. They are actually read in a seemingly random order each time.
I suspect VISA is serializing the serial port access and a race condition sets the order they are read, but that's just an uneducated guess.
=== Engineer Ambiguously ===
Message 14 of 23
(2,056 Views)
Hello GerdW,
I have done some work for parallel visa read
please have a look and let me know weather I am going good
I cant able to attaché VI because my system doesn't allow to attaché the VI so I attached VI picture
Message 15 of 23
(2,046 Views)
Hi Vinay,
you're on the right track…
Some comments:
- Don't open and close the COM ports in each iteration of your loops. Open once BEFORE the loop, close ONCE after the loop…
- You initialize the COM port to support a (default) TermChar: don't use BytesAtPort then! Just read more bytes than your largest message will need…
- As long as you use BytesAtPort you need to add an additional wait function in the loop. But using BytesAtPort is wrong anyway…
- I would suggest a larger timeout value for your COM port initialization…
- I would parse the COM port alias in a more robust way…
- Clearing the COM port buffer with each iteration usually only leads to loss of data and incomplete messages!
Message 16 of 23
(2,048 Views)
thanks for replay GredW
I have changed VI based on your suggestions and attached
I have some questions below
I would parse the COM port alias in a more robust way...
I really didn't get what alias mean. I feel its basic thing but sorry I don't know
thank you for your support
have a nice day
Message 17 of 23
(2,039 Views)
Accepted by Vinaygowda
Hi Vinay,
Right now you find all VISA resources and convert the array into a single string.
Then you search for e.g. "COM3" in this string and use the found "COM3" again to open the VISA resource.
Why do you even search for COM3 when you use this anyway to open the port?
Why don't you handle "not found" conditions???
- As you don't use BytesAtPort anymore (which is good!) you don't need to put a wait function into the loop: VISARead will wait on its own when receiving messages…
- You can connect the error wire directly to the stop condition of the loop(s)!
- You don't need to clear the COM port buffer before closing the port…
Message 18 of 23
(2,035 Views)
hello GredW,
because I need different VISA read function to open specific com port. any way I using NI rs232/4 serial port device to connect so I ll connect 1st machine to port 1 and 2nd machine to port 2 so on. then com port number will be same and 1st row of visa read will read only from COM 3 and 2nd row must read from COM 4
please correct me if I am wrong
Regards, Vinay
Message 19 of 23
(2,032 Views)
@RTSLVU Hi, I'm looking for information to Yokogawa wattmeter and if I well understand maybe you use the same as I. It's an old WT230 and I have problem not to send request but to keep back query. Can you contact me about this ? Thank you to help me to solve my problem. You can contact me by MP. Rgs Vr0.
Message 20 of 23
(534 Views)
