Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Read Directory Listing of a password protected Folder
geotos
Member
12-03-2004
05:04 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello all,
I am using an Intranet, and I want to read the directory listing of a password protected Folder, which is located onto an other computer.
Geotos
0
Kudos
Message
1
of 3
(2,861 Views)
Reply
Re: Read Directory Listing of a password protected Folder
Kress Matthias
NI Employee (retired)
12-06-2004
06:49 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
hello,
in the VI below is a small example. It uses the command line to map a share and log in a user, reads the mapped drive or the network-path and deletes the connection.
matthias k
NetListDirectory.vi 35 KB
1
Kudo
Message
2
of 3
(2,821 Views)
Reply
geotos
Member
Author
12-06-2004
08:01 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Matthias,
thanks for your solution, it work´s perfectly.
Geotos
0
Kudos
Message
3
of 3
(2,806 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
