Read Excel File
Hi fellow coders, I need some help on the subject of Excel Files.
Process
Read Excel File (5 work sheets)  >> Output is 5 2D Array's >> Covert 2D Array to Single Array (Colum) >> Convert Data (String's)to Relevant Datatype (I/O, Numeric etc) >> Build Cluster Array with 2D Array Data.
I need some help with interpreting the Covert 2D Array to Single Array (Colum) >> Convert String to Relevant Datatype >> Build Cluster Array with 2D Array Data.
Happy Coding
Dave
Message 1 of 8
(5,249 Views)
Reshape Array
Too vague. What strings? What datatypes?
Array to Cluster or Build Cluster Array, depending on exactly how you've got the data collated.
Message 2 of 8
(5,245 Views)
I have 5 2D Array's to which I need to split into 1D Array Clusters, the data types are strings within the 5 2D Array's and I wish to split them up per row and connvert them into a 1D Array Clusters containing the following datatypes
I/O
Boolean
Numeric
Message 3 of 8
(5,237 Views)
Accepted by topic author ds1638
You could do something like this:
Message 4 of 8
(5,221 Views)
How do you convert a string to a file I/O data type ???
Message 5 of 8
(5,173 Views)
I'll tell you as soon as you tell me what a file I/O data type is.
Message 6 of 8
(5,157 Views)
DAQmx Phyiscal Channel I/O
Message 7 of 8
(5,107 Views)
You don't need to convert it to anything. The DAQmx VIs will accept a string for the physical channels inputs.
Message 8 of 8
(5,099 Views)
