Read From Measurement File
Data2 works fine for me.  Make sure you have tab delimited selected and you have the correct file path setup.  -SS
Message Edited by ShotSimon on 07-18-2008 03:57 PM
Message 11 of 19
(3,576 Views)
I went back and looked at the data file in excel and found that there were 3000 points.  Looks like either your file is corupt or there is a bug in the express vi.  I ended up changing Retrieve segments of specified size to 3000.  Here is the revised picture, hope you didn't turn in your homework yetSmiley Very Happy.  -SS
Message Edited by ShotSimon on 07-18-2008 04:32 PM
Message 12 of 19
(3,566 Views)
Error 4, is still showing:
   end file encountered.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 13 of 19
(3,530 Views)
Even I am getting similar results in LabView 8.2! Each time I read a file I have to manually set the sample size to the specified value so that Read Measurement File reads the entire data. How can I correct this poblem?
Message 14 of 19
(3,509 Views)
Harold, the fourth file data23 reads correctly.  Please post your *vi there may be something else going on.
AshaG, I don't know the answer using express.
-SS
Message 15 of 19
(3,499 Views)
the .vi is in the first thread of this message board TestPot.vi or somthing like that it is on page one
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 16 of 19
(3,495 Views)
Harold,
Couple quick questions, sorry but I don't use express much.
I do not have a DAQ to test out the DAQ assistant.  Does the DAQ assistant open and try to read a file?  If not then where in your code are you reading a file?  Your DAQ Assistant is set to read 100 samples but your files have 3000 samples output to them, which tells me the *.vi you posted doesn't look like it generated or tried to read the files that you posted.  It there another *.vi maybe?
-SS
Message 17 of 19
(3,490 Views)
no there is no other .vi it just won't work for what every reason i am using the scxi-1600 with a scxi-1100 now it might work better with it but i dont know
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 18 of 19
(3,486 Views)
the program itselkf has the "ask user what file to use" in it so when i push the enable button it shows a screen that allows me to select a file
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 19 of 19
(3,485 Views)
