Read From Spreadsheet File help
I am saving all my data to a text file (See attached file). The problem is that when I try and use the Read From Spreadsheet File.vi I am unclear on how to make it show all my data.
Does anyone know a away for me to read the whole file and display it all at once reather than line by line?
(4,253 Views)
Accepted by xXChazXx
Hi xXChazXx,
please see the attached picture. If this not help, then please explain what you need.
Mike
(4,250 Views)
 The read from spread sheet Vi has two data outputs : the top right retrieves the whole file as a 2D array, if you leave the "number of rows" input on the left unwired.
Message Edité par chilly charly le 01-07-2009 11:22 AM
Chilly Charly    (aka CC)
(4,249 Views)
MikeS81 wrote:
Hi xXChazXx,
Mike
Thanks. Works perfect 🙂
xXChazXx
(4,229 Views)
