Read Multiple analogue data using VISA in Arduino
I am trying to separate the Voltage and current value coming from serial port using VISA. But only first value is reading. What would be the error? This is my LabVIEW fileThis is my LabVIEW file
This is my Arduino code
void setup() {
  Serial.begin(115200);
void loop() {
  float voltage = analogRead(A0);
  float current = analogRead(A1);
  Serial.print(voltage);
  Serial.print(",");
  Serial.println(current);
  delay(100);
Message 1 of 11
(4,046 Views)
Hi Gappiya,
why do you convert a string of two values into a 2D array of data?
Why do you try to index row 0 and 1?
Why do you use such a format string for this specific conversion function?
Suggestion:
Replace SpreadsheetStringToArray by ScanFromString and use the same format string to get two outputs from your two values (per message)…
Message 2 of 11
(4,043 Views)
The Spreadsheet String To Array function defaults to using the tab as the delimiter while your sketch is using a comma.  But that does not matter here since you would be better off here just simply using Scan From String to parse the string into the two values.
Message 3 of 11
(4,011 Views)
void setup() {
void loop() {
  Serial.print(",");
  delay(100);
For such a simple task, LINX or Hobbyist toolkit will simplify the code a lot.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019TmpSAE&l=en-US
Santhosh
Soliton Technologies
Message 4 of 11
(4,005 Views)
Knight Of NI thanks for solution i have added ScanFromString and this errors came up.
Message 5 of 11
(4,001 Views)
Hi Gappiya,
why do you want to apply Waveform functions on scalar samples?
Why do you even need ExpressVIs for the task? (ToDDT is an ExpressVI…)
Why don't you handle errors programmatically?
Did you receive the string as expected by ScanFromString?
Message 6 of 11
(3,986 Views)
Hi GerdW
I used Waveform functions to offset the signal (2.5V to zero)
I used ToDDT because Waveform functions accept Dynamic data
What string should include for the ScanFromString (%f,%f or %f)
Thank you
Message 7 of 11
(3,977 Views)
Hi Gappiya,
  • You can use a simple add function to apply an offset.
  • Waveform functions accept waveforms, otherwise they show a coercion dot. Do you know what a coercion dot indicates?
How does the received string look like when error 1 pops up?
The format string should match the format of the received string (or vice-versa)…
Your code:
Serial.print(",");
results in a message like "1.234,5.678\n" (with "\n" marking the LF char added by println), so the format string should be "%f,%f".
Is your computer set to use English numeric format with the point (".") as decimal separator char?
Message 8 of 11
(3,975 Views)
1. Just use the Add function to the sample.
2. The Waveform functions accept Waveforms, which can be coerced from the DDT.  But if you just use the Add function instead of the Waveform Scale & Offset, there is no need for the ToDDT.
3. The format string should be "%f,%f".  If there is a possibility your system uses the comma decimal separator, you should use "%.;%f,%f".  The "%.;" forces the Scan From String to use the period as the decimal separator.
Message 9 of 11
(3,961 Views)
Thank you very much for the comment. I did the modifications but neither "%f,%f" or "%.;%f,%f" working. still i am getting same error image.pngimage.png
Message 10 of 11
(3,947 Views)
