Read Text row by row, plot them and find the max of its Power spectrum
Hi, everyone,
I have to read data from a text file, plot as a time serie and find the frequency to its max power spectrum. I found a previous post related to my issue so I revised his example a little bit. But once I decide to store the data into an array, the Labview reported:' Error 1 occurred at Scan From String (arg 1)'. Can anyone help me out?
Thanks in Advance!
Gab
(3,532 Views)
Hi Gab,
the error pops up because the last two lines are empty. I have modified your vi. See the attachment please. Hope it helps.
Mike
(3,511 Views)
How come my reply to this in the morning NOT got posted... ?!Smiley SurprisedSmiley Mad
Hi Gab,
You can simply insert a Trim Whitespace after the string & get the job done. This is what I posted then.
- Partha ( CLD until Oct 2027 🙂 )
(3,496 Views)
Again my attachment got missed out. Smiley Sad
(3,494 Views)
Guys, thank you all so much! Smiley Very Happy
Finally I used a Trim WhiteSpace.vi to fix this. But Mike's solution is more useful if I want to identify special character from the string.
Gab
(3,459 Views)
