Read Traces
I`m using LabVIEW DSC 7.1 and want to show differnet data vom Citadel in an X/Y Diagram (this Diagramm_test.vi I`ve attached). In the start - sequenze 2  I use the ReadTraces.vi to get data from the last day. To load data from 9 tags it takes up to 10 seconds. Log Deadband (1%) Log Resolution (0,1%) are checked so the the amount of data is not to lage.
How can I make the ReadTraces.vi much faster.
Mann thanks for any help.
Martin
(3,155 Views)
You need to include the subvi diagramm.vi it is not in the orginal atachment.
Tim
GHSP
(3,136 Views)
Sorry , this Diagram_test.vi  and the ReadTraces.vi uses a lot of subvi`s so I have now only made a screencopy to see how the readTraces. vi is used
(3,118 Views)
