event log from CFP2020
Hi again all!
Small query here - while running a vi on a CFP-2020 device, is it possible to log events onto a CF card?  For example if button 'A' is pressed on a touchscreen controlling the vi in the CFP2020 unit, and event 'B' occurs, is it possible to log when and how often this happens?
Steve 🙂
(2,873 Views)
You can use event structure to capture event on touchpanel, and pass a data via shared variable.
Then, on cFP, read data from shared variable and write to a file on compact flash.
(2,849 Views)
Magic!
I'll have a look - that gives me hope 🙂
Any tips you may have to aid me doing this please add as well - thankyou so far 🙂
Steve
(2,843 Views)
