Read all bytes from any file
Hey! I would like to read any type of file and read them as binary (Obtain an 1d array of U8 or an 2d array 8bits x sizearray) and when I have manipulated it, rebuild the original file.
Message 1 of 11
(5,817 Views)
Accepted by Pepe727
Hi Pepe,
Use ReadBinaryFile function…
Why do you want to manipulate anything, when you need the original file afterwards???
Message 2 of 11
(5,812 Views)
Well such a vague question demands an equally vague answer.
=== Engineer Ambiguously ===
Message 3 of 11
(5,811 Views)
I wanna encrypt any file, for example a vi or a video or a simple .txt, so, when this file encrypted is decrypted...
The function "read binary file" is able to read any type of file?
Message 4 of 11
(5,794 Views)
since every file is just a bunch of zeros and ones ... yes
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 5 of 11
(5,786 Views)
Does anyone have an example?
Message 6 of 11
(5,781 Views)
RTSLVU had an example for the encoding,
to reverse that, you just have to do the same with F^-1 for the decoding.
Message 7 of 11
(5,771 Views)
The "vague answer" above is actually a good starting point!  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(5,769 Views)
See my suggestion here https://forums.ni.com/t5/LabVIEW/Can-you-give-me-some-suggestions-for-encryption-decryption/m-p/2529...
Message 9 of 11
(5,768 Views)
if you want to have "secure" encryption, use an external library/program that does that for you, like openssl, and not build it yourself.
you could run commandline call through the system-exec-vi.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/platform/system-llb/system-exec-vi....
Message 10 of 11
(5,757 Views)
