Read csv into individual arrays
I'm trying to read a csv file with 2 columns into 2 separate arrays for interpolation. But I am unable to convert the read data into arrays.
Attached is the VI for reading and displaying data.
(11,754 Views)
Accepted by utkarsh.17
You probably should also attach one of your csv files.
(In general, to get a row or column, "index array" is the right function, just keep one index dimension disconnected.)
(11,745 Views)
Here is an example csv
(11,732 Views)
Thanks. I first used transpose and then index to get x and y.
(11,728 Views)
As altenbach said, you're looking for the Index Array function.
You can drag the bottom edge downwards to get two indexing operations in one node. Just wire the 'Column' index and leave the row index blank.
GCentral
(11,714 Views)
If you wire to the lower dimension, you don't need to transpose.
(You can also select "transpose" when you read the file (boolean input). Then simply omit wiring any indices to get the first two columns.)
(11,711 Views)
Worked perfectly. Thanks for the help 😄
(11,702 Views)
