Read data from Excel
Hi ALL.
I have a bunch of values in my excel data.
However, I need to read the value for every next 10 values.
Example,
1    ----- First reading
2
3
4
5
6
7
8
9
10
11 ---- second reading
20
I try to use LLB Manager before. However, it doesnt work as wanted.
Anyone can help me.
Thank you.
(5,190 Views)
It would be better if you posted your 'excel file' so we know what format your data is stored in. In that case, you don't have to use the VIs in the llb file that you have attached; you could use something simpler like Read from Spreadsheet file or use advanced File I/O functions to set the file position and, then, read the data easily.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,187 Views)
Kindly find the attachement below.
I need to read data from -360, -350,-340,...,340,350,360
(5,180 Views)
Accepted by topic author Fird
The first thing you should do is rename the library. "LLB Manager" is a built-in LabVIEW tool for managing libraries. This can cause confusion.
What exactly doesn't work? What have you tried? You specify the start/stop range, and run the "Get Excel Values" VI. Example:
You have 2 options:
  1. Call the VI for each cell you wish to read.
  2. Read all of the values and index them out based on getting the ones that are mulitples.
The latter will require more memory since you have to read in all the values, but it will be faster.
Message Edited by smercurio_fc on 03-13-2009 09:41 AM
(5,143 Views)
Dear ALL,
I manage to solve the problem. What I did was taking out all the value needed and stored in another Excel file.
It is much more easier eventhough it is not preferrable method.
Merci.
(5,137 Views)
Well I wouldn't call that easier. Did you try suggestion (2)? It's quite easy, especially since your data is evenly spaced.
(5,133 Views)
Yeah.
Thanks a lot!
(5,122 Views)
