Read error (VISA: (Hex 0xBFFF0015) Timeout expired before operation completed) in VI Test panel while connecting Arduino.
Greetings there,
I am new to LabVIEW and forums. I am trying to connect my Arduino to LabVIEW for which I came to know that I first should check the I/O communication in VISA Test Panel. I connected Arduino Due and Arduino UNO, separately, and tried to test the command (*IDN?\n) which is already mentioned. But with every Arduino, everytime this error comes up (VISA: (Hex 0xBFFF0015) Timeout expired before operation completed). I tried with different Baud rate, stop bits, parity settings, changing cables, increassing the timout time, but nothing worked.
Arduinos are working fine  with Arduino IDE and are being detected properly.
What should I do? Please Help.
(1,254 Views)
@A.S.H wrote:
Greetings there,
An Arduino will NOT respond to an IEEE common command query like *IDN?
Unless of course you program it to do so.
The Arduino IDE is made specifically for Arduino's and is doing some kind of chip ID. It is not using IEEE commands like VISA communicating with an IEEE 488.2 compliant piece of test equipment.
=== Engineer Ambiguously ===
(1,248 Views)
Thank you for your reply.
Okay, so can I begin writing LabVIEW programs straightaway? Or is there any other command which will serve as a test to confirm the communication between Arduino and LabVIEW?
(1,242 Views)
Accepted by topic author A.S.H
Yes, VISA can communicate with an Arduino just like any instrument on a serial port. Here's my prefab answer to using LabVIEW with an Arduino
In general there are three ways of using LabVIEW with an Arduino
  1. Program the Arduino in the native Arduino language.
    1. LabVIEW can communicate with an Arduino using VISA just like any other instrument on a serial port.
    2. IMHO: This is the best way as you have full control over the communications protocol and you can use any of the of Arduino libraries and LabVIEW toolkits that are already out there.
    3. I highly recommend watching this video on serial communications: VIWeek 2020/Proper way to communicate over serial
  2. Use LINX (Hobbyist Toolkit or whatever they are calling it now)
    1. Full LabVIEW integration, but limited amount of Arduino libraries and peripherals directly supported
    2. The Arduino basically becomes a tethered DAQ device that needs to be connected to a computer/LabVIEW to work
  3. TSXperts Arduino compiler for LabVIEW
    1. Actually turns LabVIEW into compiled Arduino code. (A real feat on its own)
      1. Limited subset of LabVIEW vi's and primitives
      2. Very limited support for Arduino libraries
      3. Development seems to have stopped, so those annoying bugs are here to stay
(1,233 Views)
Thank you so much!!!
I will try to make LV programs and test through Serial communication only. Let's see what happens 🙂
(1,224 Views)
Looks like TSXperts is totally dead now.
(1,176 Views)
You can still get it from NI Arduino™-Compatible Compiler for LabVIEW
(1,110 Views)
