Read error using RS232
Hi, yes, wahat I want to send is a pelco-D command,
which is something like tht for left panning:
Message 31 of 38
(2,678 Views)
sabrinabangert wrote:
I use LabView 8.5. I did not connect any hardware device to the com ports.
1. For the first I only wanted to try out the example "BasicSerialWriteAndRead.vi".
2. But I get no read-output      --      (but no error message, nothing. It terminates after timeout without any message)
Then of course you are going to have a timeout.  If the device is not connected, there is no way you are going to get a response from it.
Message 32 of 38
(2,673 Views)
thanks a lot for the response. Then I will connect the compuLab on COM1.
I can send the pelco-D command from the C# program to Com1
and try to read the buffer from LV.
Is that correct? Could it work?
Sabrina
Message 33 of 38
(2,670 Views)
Yes.  Connect the cable.
You will not be able to write to the serial port in C# and read from the serial port in LabVIEW.  Only one program can have access to the serial port at a time.
Do you have any kind of communications manual that describes the command and message structure for communicating with this instrument?
You could try using a program such as Portmon to snoop on the serial port while the C# program is communicating with it.
Message 34 of 38
(2,668 Views)
The snooper , yeah,  thats what I search. Where can I find it?
Message 35 of 38
(2,665 Views)
Aaaahhhh here -> http://technet.microsoft.com/de-de/sysinternals/bb896644.aspx --  that's super, that's phantastic.
Thanks a lot good guys.
Best regards
Sabrina
Message 36 of 38
(2,664 Views)
Message 37 of 38
(2,661 Views)
This is getting a bit silly. You've posted a large image with no explanation of what it is or what it is supposed to mean. You have consistently failed to provide a detailed explanation. Any person in any type of technical field should be able to provide a lot more details than what you have.
Message 38 of 38
(2,628 Views)
