Read from RS232 problems
We are trying to understand exactly what characters the PIC is transmitting.  In your printf statements you have "\n" shown. What is the decimal or hexadecimal value of the bytes transmitted when "\n" is sent?
Lynn
Message 11 of 21
(1,883 Views)
this is an printscreen of my terminal... I think "\n" is "0A" in hex
http://img829.imageshack.us/img829/4572/xyt7.jpg
Message 12 of 21
(1,878 Views)
Yes. 0A hex is a line feed character.
Since you are sending line feeds at the end of each message, you should be able to remove the Bytes at Port property node and the case structure (keeping the code in the True case only). Also remove the Wait (ms). The VISA Read will wait until the line feed occurs.
Lynn
Message 13 of 21
(1,872 Views)
hi
thanks... you can put an image for I can see what I can make this?
sorry but I only start programing Labview on last mount...
best regards
Message 14 of 21
(1,870 Views)
The while loop needs only the code which is inside the True case of the case structure.  It would look like this.
Lynn
Message 15 of 21
(1,866 Views)
thanks for all your help...
I try this example and it continue don't work
see the printscreen: http://img825.imageshack.us/img825/2740/8f6e.jpg
stay correct?
I send you my file on attachement
Message 16 of 21
(1,858 Views)
Hi
stay work... thanks... now only need put only need put "timout" on VISA Serial, to "1000"
thank you very much for all your help..
best regards
Message 17 of 21
(1,856 Views)
This was a very impressive thread, given that it seems the OP native language was not English.
Bill
CLD
(Mid-Level minion.)
Message 18 of 21
(1,852 Views)
Hi
yes.. I'm portuguese..
sorry my strange ingles
Message 19 of 21
(1,847 Views)
I am glad you got it working.
I had not noticed that you had reduced the timeout to 10 ms. You do not need the Bytes at Port property node outside the loop.  It does nothing and can be completely removed.
Lynn
Message 20 of 21
(1,844 Views)
