Read from RS232 problems
Hi
I try read an protocol from RS232, but appear an error when I use "scan from string"..
I have an PIC18F who put on serial port "fprintf(outport,"* 13:53:03 * N * 2323.453 * W * 3542.092 * 12 * 33 * 29 \n");"
on my VI I need separete all parameters.
someone can help me to see the problem?
best regards
Message 1 of 21
(4,924 Views)
I do not think your error is in Scan from String. When I put the string you posted in, it returns all the values and no error.
Most likely the problem is the use of Bytes at Port. Since the PIC is sending a termination character (\n), just set the byte count input to VISA Read to a  value larger than the number of characters you expect and let the Read wait for the \n.  Then you get a complete message (except possibly on the first iteration) and the decoding should work OK.
Lynn
Message 2 of 21
(4,922 Views)
Hi
thanks
what ou make for don't have errors?
if a make may constante "0", have problems, if I put "1" or "2", continue with problems...
the is the easy way to solve my problem? (put my protocol, in diferentes windows)
"scan Strins" is the only wait who I now to make this...
somone can help mt?
best regards
Message 3 of 21
(4,916 Views)
It looks like you have 57 characters in the string you posted. Try setting byte count to 100 or 200.
Lynn
Message 4 of 21
(4,906 Views)
An array from spreadsheet string with '*' as separator should get you an array of the parameters (though the 1st one will be empty as you start off with a star)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 21
(4,888 Views)
Hi
problem continue...
http://imageshack.us/a/img11/4513/usk5.jpg
now appear new error. :S
Message 6 of 21
(4,864 Views)
Lynn,
Take another look at that PIC output
the last two chars are "\n" thats NOT an ascii escaped newline
Message 7 of 21
(4,858 Views)
Hi
I program with CCS, and output printf is:
"  fprintf(outport,"* %s * %s * %s * %s * %s * %s * %s * %lu\n",time, PNS, lat, PEW, longi, speed, alt, temperatura);"
I have "\n" on final...
Message 8 of 21
(4,854 Views)
Let's take this one step at a time. Does your PIC transmit a Line Feed character at the end of each transmission? Or is it literally sending a backslash character followed by a lower case n?
Lynn
Message 9 of 21
(4,841 Views)
Hi
I don't understand your questions johnsold...
my PIC put on serial port this string every 1second
sometimes it work... but after a few second program crash and when crash, on window "dados do circuito", don't start on 1º parameter...
if I only read string, when I receive an char like "#" ou an letter, I forced the program to read correct string, I think (with this I change my printf to have this 1º char before the "*")
best regards
Message 10 of 21
(4,830 Views)
