Read from Spreadsheet file reads only one column
I have attached an extremely simple VI and also a csv file.  The Read from Spreadsheet File reads only the first column.  I have checked the delimiters in Notepad and everything looks OK.  Any ideas?  Thanks.
(4,419 Views)
Accepted by topic author Wayne_B.
Ditch the space after the comma when specifying the delimiter.
(4,417 Views)
Thanks so much, Darin.  It worked!  I have no idea how the comma got there in the first place.
Wayne
(4,414 Views)
could you please upload your VI compatible to LabView 2013?
Thanks a lot!
(3,705 Views)
Hi lab-fellow,
Wayne hasn't visited the forums since 2016, but you can always start a new topic if you're having problems.
(3,701 Views)
Hi gregoryj,
could you just pick the VI above and convert it to LabView 2013?
I'd appreciate that very much!
(3,698 Views)
It's just the read from spreadsheet file vi
(3,695 Views)
