Read memory inside a timed loop
I’m sending data from host to target using a FIFO, and then I stock them in a memory, which I will need to read from each time I need my data, the problem is that it must to be inside a timed loop, but when I tried to read in that case I got an error as shown in the screenshot. I don’t understand the problem exactly nor how to fix it !!
(1,691 Views)
Accepted by User_OP
Hi User_OP,
Did you read (and try) the solution given in the error dialog "Details"?
Have you tried to wire the output of the ReadMemory operation to a shift registers instead of an indicator?
Btw. when you would use AutoCleanup then your VI would require just 1/3 of the screen instead of more than one FullHD screen…
(1,675 Views)
Accepted by User_OP
You defined yourself, that you need 2 cycles before the data of a memory item becomes available:
Use a shift register as Gerd suggested (but then with 2 cyles) or decrease the number of read cycles to 1.
For further details I suggest to have a look at the example
"Memory with Cycles of Read Latency.lvproj" from the NI Example Finder
Regards, Jens
Regards, Jens
Kudos are welcome...
(1,657 Views)
