Read multiple channel data from LVM file
I have a VI where I can save the signals from 96 channels in a LVM file  using "Save to ASCII/LVM Express VI" and it works fine. In other VI, I am using "Load from LVM Express VI" to read the previously saved file, but only 20 signals are shown. These 20 signals are ok, but I want all 96.
I attached  the LVM file and the VI where I am trying to read it.
Thank you all
Frederico
(3,512 Views)
Accepted by topic author freddearaujo
Hey Frederico,
I used a different Express VI (Read From Measurement File) to read your LVM File and I could get 98 channels.
Here is the code snippet...
...and the Front Panel
Try it out and tell me if that worked for you.
Best,
Felipe Flores
Applications Engineer II
National Instruments Brazil
(3,484 Views)
It's working here too.
Thank you!
(3,476 Views)
