05-13-2009 08:17 AM
I need to open a data sheet and cells of OpenOffice calc through LabView, but I don't know how to do it.
Does anybody know how to do it? Or anybody has an example?
Thanks!
05-13-2009 09:57 AM
You should take a look here: http://forums.lavag.org/Reports-with-OpenOfficeorg-t3368.html.
OpenOffice has an ActiveX control so you may also be able to do it that way.
Another option is to save the data sheet as a text file and the use the Read From Spreadsheet File VI (File I/O palette).
05-13-2009 12:23 PM
This idea is good, but I would want to select the cells that I would need to read. For example: A1 and after D5.
How do I would do this with text file?
05-13-2009 12:32 PM
05-13-2009 01:14 PM
I think very good, but I didnt find none example this. Anyone has?
Im studying the example "Read from Text File".
My LV is 7.1.
Tks!
05-13-2009
01:19 PM
- last edited on
05-06-2026
10:05 AM
by
Content Cleaner
It will be easier if you use the Read From Spreadsheet File VI as I had mentioned, since that will return a 2D array for you directly.
05-13-2009 01:28 PM
