Read single row and multiple columns in excel sheet using text ring (property string).
I am trying to use excel datasheet to feed data to the front panel text ring. Problem with the method I have applied is since the excel file has 3 columns, I have to select data from each column separately. What I am trying to achieve is 1) Selecting any data from one column should automatically pull the corresponding data from the same row. 2) This data should be Indicated on the front panel. 3) Data selected should also be recorded in the final report.
I have attached the code so far I have tried and excel file as an example.
Message 1 of 9
(5,029 Views)
Oh, come on!  This is a LabVIEW Forum.  If you have LabVIEW code for which you want help, attach your LabVIEW Code.  Don't send us a Microsoft Word document (unless it is a multi-page treatise on all the things you tried, with diagrams, etc.).
Message 2 of 9
(4,996 Views)
Sorry for my mistake. Here is the LabVIEW code I tried.
Message 3 of 9
(4,991 Views)
LOL Bob "Triggered" Schor. Smiley Very Happy
aputman
Message 4 of 9
(4,983 Views)
Accepted by vinod.4166
use the row-defining enum "code" as a control and the other two column enums as indicators
Message 5 of 9
(4,969 Views)
Thank you so much. It works exactly the way I wanted.
Is there a way to access Excel sheet data in the VI without opening the excel file every time the program runs?
Message 6 of 9
(4,964 Views)
You can set the window state of the Excel Application to "minimized" or "no change"
take a look at the "new report.vi" help
Message 7 of 9
(4,960 Views)
Thank you once again. My bad, I did not read before asking a stupid question.
Once again thank you for your kind help sir.
Message 8 of 9
(4,955 Views)
Setting the window to minimized prevents the window from flashing to the user but the Excel file is still opened every time the program runs.
aputman
Message 9 of 9
(4,946 Views)
